Panasonic PTV model PT/51HX40B convergence question
A
AJ
Probably part of the Deflection Board, Should be able to change the STK
devices and check the low value yoke return resistors for value changes.
Either chassis removal or board removal will allow access to the components.
Original STK probably 392-110.
- Show quoted text -
So I imagine that it would probably be prudent to replace them with
150's? Lenny.
A
AJ
Correct, also clean all the old heat paste off the sinks and apply a liberal
amount. Good Luck.
