Panasonic microwave - only stop & start buttons working
Discussion in 'Hobby Electronics' started by Rob Farley, Apr 24, 2004.
  1. Rob Farley
    Rob Farley Guest
    I have a Panasonic microwave, model NN-5454B (white one that says
    "Welcome to word prompting" when you turn it on. Yesterday all the
    buttons except "stop/reset" and "start" stopped working. Tried
    resetting the power - still no luck. Can't make it cook, obviously,
    because I can't tell it how long or how hot to cook.
    It seems like a little thing, as if the keyboard on my PC needed a
    service. But how should I fix it? The thing is nine years old, but
    it's still a good microwave, and it seems like a waste to just replace
    it on a little thing like this.
    RobF
  2. Bill Bailley
    Bill Bailley Guest
    You may possibly trace this to the keypad having been sprayed with Windex
    and then cleaned. Does the keypads in a treat.
    Bill.
  3. Derek
    Derek Guest
    As a guess, beacause all the buttons died at once, bar 2,
    it seems unlikely that that contact points are to blame. That would
    involve serious coincidence, unless something like water or an
    exploding egg found it's way there.
    Good Luck.
  4. Bill Bailley
    Bill Bailley Guest
    That can work if it did not get too wet. The usual trouble is that the
    cleaner wicks up into the pad and into the flex connector. Can take quite a
    while to dry out.
    Another failure mode for these critters is a stuck pad. This is mostly
    caused by poking the pad with a fork or spoon. This fault can usually be
    seen or felt by a careful examination.
    Sadly the age of the oven would seem to indicate that a replacement would be
    indicated.
    Bill.
