Panasonic KX-TG2570 - Hack
Discussion in 'Electronic Repair' started by Michel Peterson, Jun 6, 2005.
  1. I have a Panasonic KX-TG2570 and it's causing interference with my WiFi
    Router so I was wondering if it is possible to remove the 2.4 Ghz
    support and make it work only with 900 Mhz support, since it uses both
    bands I thought it could be possible... Any ideas on how to do this?
    Does anybody has the schematics of the phone?
    Thx in advance
    Best Regards
    C00I90WN
  2. Art
    Art Guest
    Try relocating the phone and it's base assembly further away from the
    router. Or try orientating the antenna on the router. May be no correct way
    to eliminate this interference. Modifying the phone may render it
    inoperable. Contact Panasonic directly and ask them if there is a way to
    have these items function in the same general areas without the
    interference. .
  3. C00I90WN
    C00I90WN Guest
    I tryied everything, within my possibilities, to reduce the interfence
    to the minimum but the phones seems to be really powerful since it
    interferes anyway, so I think the only thing I can do is trying to
    remove the 2.4Ghz or sell it and buy a new one that works only at 900
    Mhz. However if anyone thinks that is it possible to "hack" it, please
    let me know.
    Best Regards
    C00I90WN
