Panasonic KX-TG2500S
Discussion in 'Electronic Repair' started by Hernán Sánchez, Dec 30, 2003.
  1. Hi.
    I have this phone, but a special kind of diode is broken... it is Z607. I
    think is a rectifier. I want to replace it, but I cannot find its
    datasheet. Does someone has any idea of what is it and what can i use to
    replace it ?
    Hernán Sánchez
  2. Jerry G.
    Jerry G. Guest
    This is a Zener diode according to the location description. You can get a
    number of them in the 3 to 10 volt range, and try them to see which one
    works the best. They are not expensive. When you try one that is close to
    the proper value the unit will work, if there are no other faults. Most of
    these in the small phones are rated at 1/4 or 1/2 Watt. Get the 1/2 Watt
    type to experiment with.
    Panasonic does not sell their cordless phone service manuals any more. They
    will tell you to send them the phone. Most of the time, they service these
    at a flat rate. You have to call them.
    The service rep for your area should be with the instruction sheet that came
    with the phone, or there will be general authorized service information.
    Most models have an 800 number sticker on the bottom of the base unit. You
    will need the model number of the base unit when you call them.
    When we get these from out customers, and it is not a simple fix, we call
    the manufacture to have an idea of the base cost, and send them the complete
    phone for service. This usually works out more efficient in the end, and
    there is a 90 day warranty for the repair.
    We also found that it was generally not worth to service these if the phone
    was more than about 3 years old.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    Hi.
    replace it ?
    Hernán Sánchez
