Panasonic DECT on Hook inactivity Timeout
Discussion in 'Electronic Design' started by Martin Riddle, Mar 28, 2013.
  1. I have a KX-TG7641 DECT phone that works pretty good. I just discovered
    it can pre dial an area code!, great for FIOS.
    But, one problem is that it is easy to leave it on hook if you don't
    press OFF.
    This is kind of silly, I looked through the manual and don't see a
    timeout for it at all. Did I miss something?
    Perhaps I should add a one shot triggered by voice activity that would
    send a pulse to the OFF button if its left on Hook.
    Cheers
  2. Phil Allison
    Phil Allison Guest
    "Martin Riddle"
    ** The term "on-hook" means the phone is off and waiting for a call.
    ** All the cordless phones I have seen are the same.
    You have to push "OFF" or put them in the charging cradle to get an "
    on-hook" condition.
    .... Phil
  3. Thanks, I meant Off-hook. Still, if you don’t place it in the charging
    cradle, it may never go on-hook for hours.
    Cheers
  4. Martin Brown
    Martin Brown Guest
    It does eventually though when it runs out of battery power.
    It seems to me like the phone could sensibly drop the line after 10
    minutes or so with no sounds on either end.
    I once had a very annoying early pre-DECT wireless phone which did not
    drop the line if you put it back in the charging cradle without first
    pressing the red end_call button. It was a disaster.
    It also had lousy range in a brick walled house and the thermal fax
    paper for the base station was extortionately priced into the bargain.
    This was the final straw after junk faxes became all the rage.
