Panasonic CT36SX31E Power surge takedown
Discussion in 'Electronic Repair' started by [email protected], Mar 27, 2007.
  1. Guest
    A power surge literally blew apart the power supply transistor,Q801, a
    2SK2917LB. There is a diode D862 across this transistor that was
    shorted. Also shorted was D824 which is across the output of the
    regulator IC801, AN8029. IC 801 a PC123 the opto IC was leaking as
    well. I am going to replace the AN 8029 along with the other parts
    since its output had a shorted diode across it too. Has anyone seen
    the power supply mosfet actually blow apart on one of these things
    before? I have no schematic of this set and was wondering if anyone
    had one that they could share with me. It would be really helpful to
    be able to see whats in there. Thanks a lot. Lenny Stein, Barlen
    Electronics.
  2. replace all parts listed and check R 814 & 813
    costco set model search on AAA comes up but wrong
    chassis use ct 27sx chassis (previous year)
    Ap381 chassis
    d806 au01zv0 shorted
    d824 shorted tmpg10g3
    d861 862 shorted tvsa81004v3
    ic 801 an8029
    q801 2sk2759f217r blown
    r819 open erds1fj103h
    r820 0pen erds1fj390t
    fuse blown
