Panasonic cordless telephone - battery problem?
Discussion in 'Electronic Repair' started by [email protected], Jul 13, 2005.
  1. Guest
    Hi there!
    I was hoping that someone could help me with a problem I'm having.
    2 years ago I purchased a Panasonic KX-TG2650CN cordless telephone for
    my father. He decided not to start using it until last week when his
    old cordless finally died. The battery was already installed in the
    handset, so it had been in there for at least 2 years (if not longer).
    He allowed the unit to charge 8 hours, and when the green light came on
    (indicating complete charge), he took it off the handset, and made a
    phone call. When he was done, the handset shut off as if there was no
    power. He then charged it again, and the same thing occured.
    The interesting thing is that it doesn't matter whether the phone call
    is 5 minutes or 4 hours; as soon as he makes one call and hangs up, the
    phone dies.
    He went out and purchased a replacement Panasonic battery (indentical
    model #) and he is still having the same problem.
    I was wondering; what could be the problem? Has this phone always been
    defective, or was it caused by the fact that the battery was left
    installed for so many years?
    Any advice would be greatly appreciated.
    Thanks in advance!
    Scoobadivr
  2. NSM
    NSM Guest
    That's my guess.
    As long as it wasn't ever charged it should have been fine. Try charging it
    for 24 hours before using it again.
    N
  3. Rono
    Rono Guest
    These phones have a big battery/charging problem. We have three
    at or shop, charge them for fifteen hours, & run them till they run right
    down, otherwise they won't last very long at all!! have a look here at
    the reviews. You can "very carefully" put a load accross the battery
    pack, to "run it down", then charge it for fifteen hours, but you must let
    it run right down. Rono.
    http://reviews.cnet.com/Panasonic_KX_TG2730S/4514-3499_7-20604770.html
  4. Guest
  5. NSM
    NSM Guest
    If you don't know, don't try.
    N
  6. jakdedert
    jakdedert Guest
    Bullhockie!
    Simply unplug the phone from the telephone jack and turn it on. Leave it
    that way until the light goes out, then recharge. You might want to repeat
    this a couple of times...or you might want to simply get a new battery and
    try that. They're not 'that' expensive.
    jak
  7. NSM
    NSM Guest
    Balderdash! That isn't "very carefully putting a load across the battery
    pack".
    N
  8. jakdedert
    jakdedert Guest
    Just 'how' carefully must one put a load across the battery? The original
    advice was to not do it at all, unless one had some arcane technical
    know-how, implying that it was dangerous. I merely pointed out that it was
    not all that difficult, and not dangerous at all, if done as outlined.
    Someone *emailed* me to say that it might not be possible to do as I
    detailed. To that person: I've not seen a phone which will hang up on its
    own, as postulated. Perhaps there are some out there. In any case, please
    limit your replies to this forum. It's bad form to email a reply.
    jak
