Panasonic Answering Machine Volume Adjustment
Discussion in 'Electronic Repair' started by WbSearch, Aug 29, 2004.
  1. WbSearch
    WbSearch Guest
    Sorry if this is a duplicate, I didn't find the message today that I posted
    yesterday.
    Is there a way to increase the playback volume when retrieving messages by
    calling a Panasonic model KX-TM100B, answering machine? The volume control on
    the unit adjusts the internal speaker, but doesn't affect the volume thru the
    phone line when I retrieve messages while traveling and calling the unit.
    Panasonic tech. help had no advice.
    Thanks.
  2. Jerry G.
    Jerry G. Guest
    From what I have seen in these answering machines, there was no control of
    such that your are requesting. Most likely this parameter is burned in to
    the machines software, and would not be accessible. This is why the
    Panasonic tech was not able to have the solution.
    The only option you have is to send the machine to Panasonic, and they will
    be able to do a performance test to tell you if the machine is actually
    defective, or if it is normal in its operation. If you send the machine to a
    local service centre, they may not be of much assistance with this type of
    problem.
    Jerry G.
    yesterday.
    on
    the
    Thanks.
