C
[email protected]
This set came in with a blown 6.3A fuse. I have no schematic but I
checked for any obvious problems and found none. So I replaced the fuse
with a 4.0 amp just to test it, (I have about 150 of this size in the
shop so I don't mind sacrificing a few). When testing the set, I
disconnected the degaussing coils (because they were too short to pull
the chassis out with them connected). I powered the set up and except
for purity problems it looked pretty good. It ran for about an hour and
then I shut it off for about 30 minutes before turning it back on
again. Again it came on fine and stayed on. I degaussed it manually,
disconnected power and plugged the coils back in. When attempting to
power it up this time it initially powered up, then I heard the degauss
relay click, I heard a loud hum from the degaussing coils and the fuse
opened. I then waited about a half hour, put a 6.3A fuse in and powered
the set up. It came on fine. I've connected a 10 amp meter in series
with the AC line and each time I've tested it after letting the degauss
thermistor cool down, as soon as the degauss relay activates it pegs
the meter for a very brief instant and then settles back down to
normal. It has not taken out the new fuse though. I know initial
current on degauss is high but how high is OK I'm wondering? Should I
just change the thermistor for good measure? I hate shotgunning things
but I'm not sure. And also I must ask as simple as this circuit is
should I perhaps suspect something else? Any comments or advice are
most sincerely appreciated. Lenny Stein, Barlen Electronics
