John Larkin
I think the old intel processor you are talking about the i432 "MicroFlame".John said:John Larkin wrote:
[... CDP1802 ...]
Well, the 8051, at least in its original incantation, isn't much
of a screamer either (12 clocks per op, as well).
There's a big difference between 12 cycles of a 12MHz clock and 12
cycles of a 2 MHZ clock. Besides:
Like I said, there isn't much of a difference.
A = B + C
Compiles to something like 16 instructions if A, B and C are
randomly located in the RAM area.
The 8051 is not so different if A, B, and C are randomly located in
external RAM. I'd never use a HLL on such a beast.
MOV DPTR,#B ; 1
MOVX A,@DPTR ; 2
MOV R5,A ; 3
MOV DPTR,#C ; 4
MOVX A,@DPTR ; 5
ADD A,R5 ; 6
MOV DPTR,#A ; 7
MOVX @DPTR,A ; 8
The 8051 took 8. Now lets see if I can remember the 1802 well enough:
LD #LOW(B) ; 1 Data = low 8 of address
PLO R5 ; 2 Put to low 8
LD #HIGH(B) ; 3 Data = high 8 of address
PHI R5 ; 4 Put to high 8
LD #LOW(C) ; 5
PLO R6 ; 6
LD #HIGH(C) ; 7
PHI R6 ; 8
LD #LOW(A) ; 9
PLO R7 ; 10
LD #HIGH(A) ; 11
PHI R7 ; 12
LDN R5 ; 13 Load what R5 points to
SEX R6 ; 14 Do math with what R6 points to
ADD ; 15 Do the math
STD R7 ; 16 Store where R7 points
The instruction count for the 1802 is double that of the 8051 and with
the slower clock speed, the 1802 takes about a billion times longer to
do the same operation.
Impressive! For a 6800-family gadget, it would be
LDAA A
ADDA B
STAA C
And on the 6803, using "LDAD..." (load double etc) would do it for
word operands, using the A and B accumulators as a 16-bit register.
On a PDP-11, it would have been...
MOV.B A, C or just MOV for word data
ADD.B B, C
and the MSP430 is essentially the same, executing the sequence in
about 400 ns. Both machines allow a choice of relative (relocatable)
or absolute addressing. The rumor is that a few guys invented the
PDP-11 architecture one night in Gordon Bell's basement.
On a 68K, it would be three ops, loadreg/add/store, but you'd have
your choice of byte, word, or long.
There weren't many triple-operand machines around, ever.
John
I actually have worked with a machine that used up to 7 operands for a
single instruction. IIRC the instruction was a repeated move selective
replace using different source and destination indexes, different base
address (with a special interpretation for one), a mask value, replace
value, and iteration count.
Yikes!
Some of the CISC-ier machines, like HP 3000 and Vax and the nearly
forgotten, failed 32-bit Intel chip (what was that called?) had
outrageous instructions, like polynomial eval and hairy string ops,
but that was just tons of microcode so doesn't really count, by my
official decree. The 68332 even has a few, like the linear
interpolation thing and hi/lo limit checks.
John
iAPX432.
IIRC it was a four or five chip group for the processor (kinda like a 2901
bit slice machine) and about a 11 by 14 board full of TTL logic (kinda like
the old IBM PC or XT).
Three (monstrous) chips for the CPU, IIRC.
Interesting that the chip was sunk by its architectural philosophy. It
was designed near the peak of the Pascal craze, wasn't it? Similar to
the Western Digital p-machine and the HP3000. HP over-reacted and next
did the very risc-y HPPA, which originally didn't even have a
multiply, in the name of intellectual purity.
There seems to be an erratic relationship between instruction
set/memory architectures and market success. Some truly horrible
architectures have been big hits (IBM character-oriented machines,
PDP-8, x86, 8048/51, PIC) and some elegant ones have been hits, too
(S/360, PDP-11, Sparc, PPC). Itanic is still up for grabs, which is
interesting because of how many presumably smart people have invested
how many billions of dollars so far.
John
