PADS, jumper problem
M
mili
I route single sided board and I cannot use jumpers? When I'am trying
to put a jumper on track a message appears "Can't add jumper". When
I'am trying to put a jumper while routing nothing is happend, my comand
(Ctrl + Alt + J) is quite ignored?? What is wrong??
B
Brad Velander
mili,
Do you have the jumper feature in the modules you are running? Do you
have a secondary module that may be required for the module containing
jumpers ot work? PADs is riddled with requirements for different
mosules/functions/features to function. I don't have the answer but know
from my past experience that you used to need about 3
expansion/advanced/feature modules before the jumper feature would work.
M
martin.shoebridge
Can't you add a resistor with a value of 0 ohms?
M
mili
martin.shoebridge je napisao/la:
Yes I can. But that resistor must bi put in the scheme then. That will
be very confused. It doesn't matter any more. Thanks anyway.
