R
Robert L Bass
where do you put the ground? ive always wondered that,
On Napco panels there's an earth ground terminal. The other end should
ideally be connected to the same ground rod as the building's electrical
system. Make sure the CATV, phone and any other services are also grounded
to the same rod. If there are multiple grounds, connect them together in
accordance with NEC 250. Even though NEC doesn't apply in the Bahamas, the
principles are valid. Here's an informative article on the subject of
grounding as it relates to information technology systems. Alarms and other
systems related to our industry have much in common with IT.
http://www.itic.org/technical/ite_grnd.pdf
Hope this helps.
Regards,
Robert L Bass
Bass Burglar Alarms
http://www.BassBurglarAlarms.com
http://www.Bass-Home.com
even though down here it doesnt make any difference,
still wanna know.
Hope this helps.
Regards,
Robert L Bass
Bass Burglar Alarms
