Ozone machine Repair
Discussion in 'Troubleshooting and Repair' started by medusa, Aug 14, 2016.
  1. medusa
    medusa
    5
    Aug 14, 2016
    Hello All! I have a problem I hope I can get help for. I'm a newbie to electronics but a quick learner. I am repairing an ozone air cleaner for a friend and I replaced the corroding pots for news one w on/off.
    They seem to work fine and I am able to turn the ozoner and fan off ( shared pot on the right) whereas before it couldn't. The problem is that the ozone intensity control ( left sided pot) doesn't seem to be kicking in Even though the pot is new there must be some other component that has control of the ozone intensity. Can alone help me toubleshoot?
  2. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Welcome to EP.
    Maybe we can help.
    Do you have a service manual or schematics of the unit?
    Some photos could help as well.
  3. medusa
    medusa
    5
    Aug 14, 2016
    I thought i did upload some pics....i'
    ll try again.
  4. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Well,
    Now you did post.
    The soldering quality of the pots is very poor.
    Look here and learn how to.
    Take your time learning,soldering quality is critical for repair.
    What is the brand and model name of your unit?
  5. medusa
    medusa
    5
    Aug 14, 2016
    It is a New Comfort Model 03/1000
    ps where on the pots is poor outside of the rigged legs I had to do?
  6. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    ozone board_1.jpg ozone board 2.jpg Bad solders marked with Red good ones are like the Green.
    What was connected on the Yellows?
    What is written on Q1 and Z1 ?
  7. Sunnysky
    Sunnysky
    483
    123
    Jul 15, 2016
    There is no inductor on board to create the arc for the ozone.
    THe board seems to missing a lot of essential parts.
  8. medusa
    medusa
    5
    Aug 14, 2016
    I don't know what was connected to the yellow cublike items. I didn't touch anything except changing out the 2 pots. Before they had one regular pot and one with o/off. I switched them out for 2 new pots with o/off. Everything was fine except the control over the ozone amount generated does not change as it should. I include a pic of the rest of the air cleaner for your clarification.
  9. Sunnysky
    Sunnysky
    483
    123
    Jul 15, 2016
    The yellow Mylar insulation tape is on the stepup HV transformer.
    No idea how the pot is connected , both appear to be 500k
  10. medusa
    medusa
    5
    Aug 14, 2016
    yes the new pots are inserted the same way the old 500k were. The only difference was lack of ozone control. I wondered is that resistor on top of the one pot on your left would be instrumental in the ozone control as well. Or as a possability to offer less ozone could I safely just eliminate one plate from the setup? The lady that uses this machine does so improperly so I'd like to either have a constant reduce ozone amount or have it adjustable as it usually was.
