Overhead Projector
Discussion in 'Electronic Repair' started by [email protected], Feb 6, 2006.
  1. Guest
    My overhead projector light is dim or I can't see the letters and
    pictures clearly, is it something to do with the light or do I need
    service?
    Zee
    Thank You
  2. TimPerry
    TimPerry Guest
    LCD projector or RGB?
  3. jakdedert
    jakdedert Guest
    I believe the header says 'overhead'; in which case the OP needs a new bulb.
    jak
  4. TimPerry
    TimPerry Guest
    ah.. i was thinkin of a ceiling mounted video projector.
    check to see if you have a 220V lamp running on a 110V outlet
  5. Stan
    Stan Guest
    wrote:
    }My overhead projector light is dim or I can't see the letters and
    }pictures clearly, is it something to do with the light or do I need
    }service?
    Open the top and see if the bulb's glass is crystal clear or grey-ish;
    if it's not clear, replace it. DO NOT touch the bulb with your bare
    fingers. Clean the lens and the glass plate. Make sure the bulb's
    voltage rating is the same as the power outlet you're plugged into.
    Stan.
