Hello,
A couple of weeks ago I heard my microwave making a noise, sounded like a fan was going up in RPMs and then down again. Might not have been a fan, could have been the magnetron. Anyhow, I went outside a few hours and came back in and my wife said the microwave made a "pop" noise and wouldn't turn on. The microwave was pretty hot as one can imagine.
I'm pretty handy when it comes to pretty much anything in or around my house. I took the microwave apart and the only issue I found initially was a blown thermostat fuse (likely the pop she heard). I ordered a fuse and put it in and got power back to the microwave LCD screen.
Once I had power back I noticed 2 issues:
My initial assumption was it's the circuit board because all of the buttons would work with the exception of the fan On/Off button. Ordered new board and issue is still present.
I tested all of the thermostat type fuses (4 of them I think) for continuity and they are good. I tested all ceramic fuses (2 of them on a small circuit board separate of the main board) and the door switches (3 of them) and everything tests good. I also tested the HV cap, magnetron and HV transformer and all of those devices test within spec.
So, what am I missing? Is it possible for a magnetron to test good and be bad or maybe the same for the HV cap. I don't think it's the transformer but at this point I am down to the big 3. And I'm not sure that any of those 3 would have an effect on the exhaust fan.
Could the issue be the small circuit board (it does have a copper coil and a couple other small soldered components). I'm not sure what that board's function is entirely, but I assume it servers to deliver power to particular components since it has the 2 ceramic fuses on it.
Any thoughts would be much appreciated.
- The microwave wouldn't heat.
- The exhaust fan (not the cooling fan) would not turn off. As long as the microwave has power, the exhaust fan turns on.
