Over 10dB noise reduction at 300MHz
Jure Newsgroups
Winfield Hill said:
Sony Noise-Canceling Headphones, with
"Over 10db noise reduction at 300MHz"
http://www.ecost.com/detail.aspx?EDP=19628703&Source=EWB112407EML
I bet thay are using these Linear Technology parts available from Newark
( Grin ... )
http://www.newark.com/jsp/search/br...|1&Ntk=gensearch_001&Ntt=JFEDEUSSIGCH040&Ntx=
LT1112ACN8#PBF - LINEAR TECHNOLOGY - Operational Amplifier IC
Image is for illustrative purposes only.
Please refer to product description
Manufacturer: LINEAR TECHNOLOGY
Newark Part Number: 57M1727
Manufacturer Part No: LT1112ACN8#PBF
RoHS Compliance : Yes
Description
a.. Operational Amplifier IC
b.. Number of Amplifiers:2
c.. Bandwidth Max:750GHz
d.. Slew Rate:0.3V/us
e.. Package/Case:8-PDIP
f.. Amplifier Type:Low Power Precision
g.. Leaded Process Compatible:Yes
h.. Offset Voltage:20V
i.. Operating Temp. Max:85 C RoHS Compliant: Yes
E
ehsjr
Don said:
I can barely hear up to 96 MHz, so I limit my radio hearing to the low end
of the FM band :^)
The pharmaceutical outfits probably have a pill for that.
Of course, it would need to be used in conjunction with
oxygen-free, audio enhanced, gold plated, dynamicly balanced,
impedance matched monster cables.
Ed
B
Does mHz make more sense, or what is your point?
Oh dear.
No, three hundred millihertz would also be somewhat out of
the range of human hearing.
W
Winfield
$20 for a pair of filters with only 10dB attenuation
at 300MHz? Good God man, you can get ferrite filters
that'll do far better than that for fifty cents each!
P
Phil Hobbs
Not to mention that tin foil hats will do far better, for much cheaper.
Cheers,
Phil Hobbs
Jeff Liebermann
Nice. It probably cancels rock, grunge, techno, punk, rap, trance,
disco, talk radio, and perhaps even commercials. Only 10dB reduction
in these offensive noises isn't great, but it's a good start.
300MHz. So that's were the strange subliminal voices in my head are
coming from.
JosephKK
Winfield [email protected] posted to sci.electronics.design:
But you are not a platinum plated audiophool.
