Oven heater element.
Discussion in 'Troubleshooting and Repair' started by markm6164, May 14, 2012.
  1. markm6164
    markm6164
    118
    Jan 22, 2012
    My oven heater element has just gone tonight. Can some check my maths on what resistance i should measure the element as. Its a 240V 2000W element. I work that to be 26.45Ω. What i actually measure with my Fluke is 38MΩ which just confirms its faulty.
  2. shrtrnd
    shrtrnd
    3,773
    493
    Jan 15, 2010
    If it's a household stove, take the element into any appliance repair supply store,
    and they'll match it up for you.
    You can write down the make and model of your oven in case they need it.
    But the stores near me can just look at it and know what it is.
    95% of the time, it's the heating element itself that went bad.
  3. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    Power = V*V/R so R=V*V/P
    240*240/2000=28.8
    Resistance goes up as temperature rises so could be significantly different to this when cold. Would be interesting what the new element measures.
  4. markm6164
    markm6164
    118
    Jan 22, 2012
    The new element is coming wednesday so i will measure before i put it in. Just wondered how to work it out. Thanks duke37!
  5. davelectronic
    davelectronic
    1,087
    12
    Dec 13, 2010
    Hi there.
    I once replaced a pair of Creda oven elements, they kept tripping out the supply at the RCD i was told to burn them in slow then up the power, problem was i had to disconnect earth lead to the cooker to stop tripping out, this was a temporary measure to burn the elements in.
    Yes it dangerous to touch the unit while i was doing this, but was the suggested method after burn in i restored the earth lead and there was no more tripping out the supply, in short my supply protection is very sensitive, you probably wont have such problems, but if you do have to burn them in remember the chassis could become live ( hot ) so i would avoid touching it if you have to do it, but like i said you probably wont have to.
    Dave. :)
  6. markm6164
    markm6164
    118
    Jan 22, 2012
    I measured new element today before fitting. It measured 31 ohms straight out of the packet. So the maths wasn't far off the mark.
