oven heated diode.
Discussion in 'Electronic Design' started by Jamie, Jun 19, 2013.
  1. Jamie
    Jamie Guest
    Has any one ever applied oven heated diodes in a circuit to keep the
    Vf down to a minimum?
    I remember years ago I was tossing this idea around in my head but
    didn't have the resources to experiment with this idea.
    Thinking a glass type package may live longer.
    Jamie
  2. whit3rd
    whit3rd Guest
    A lot of NIM bin systems used the +/- 24V power supplies to
    good effect; with the right op amps, and higher signal voltages,
    the diode breakpoint thing is very well behaved.
    Modern design with +5V single supplies is just NOT well behaved,
    and (IMHO) low voltage analog design is like playing tennis
    wearing a straitjacket. White straitjacket, of course.
  3. Guest
    I'm having trouble visualizing the "feedforward nonlinear breakpoint thing"inside an error driven closed feedback loop- usually the feedforward wouldadjust a parameter to stabilize the loop dynamics which would otherwise vary widely as a function of some other input.
  4. Jamie
    Jamie Guest
    regulating steam generators are no problem, the secret is in the (D)
    parameter of the PID loop. :)
    Jamie
