output impedance of common source amplifier
Discussion in 'Electronic Basics' started by tempus fugit, Feb 18, 2009.
  1. tempus fugit
    tempus fugit Guest
    Hi;
    How do I determine the output impedance of a common source (or other JFET)
    amplifier? I know that it is roughly 1/gms, but how do you deal with the
    units? E.g., if a certain JFET has a gms of 5000 uS, the output Z would be
    0.0002, but surely that's not ohms is it? Or do you divide out the micro and
    get an answer of 200 ohms?
  2. Fred_Bartoli
    Fred_Bartoli Guest
    But the output impedance of a common *source* amplifier isn't 1/gm. That one
    is the output impedance of a common drain stage.
    For a common source stage you use 1/go
    Also note that parameters depend on the bias conditions and that those given
    in datasheets and suffixed by a 's', like gfs, gos, are at VGS=0 bias
    conditions.
    And for a R loaded common source stage the output impedance is often
    dominated by the load resistor value.
  3. tempus fugit
    tempus fugit Guest
    Thanks Fred.
    My mistake - I meant common drain; I was thinking source follower.
