OTA with linearization diodes
Discussion in 'Electronic Design' started by R. G., Sep 21, 2003.
  1. R. G.
    R. G. Guest
    A small mystery (for me...)
    from the following datasheet of the LM13700 at page 7, figure 3:
    http://www.national.com/ds.cgi/LM/LM13700.pdf
    Using the linearization diodes, input-output equation is:
    Io = 2 * Is * Iabc / Id
    and I assume:
    Is = Vth / Rth
    And if Ra << Rin then Rth = Ra
    (Rb = Ra in all conditions for the sake of simplicity..)
    Let's say Rin = 10K and Ra = 500 ohms as in figure 4.
    Now if I reduce the value of Ra, Vth will also be reduced in the same
    proportion thus Is remains *unchanged* if I read this correctly.
    If so, no matter how low Ra is reduced, I should still get the same output
    from the same Vth input signal.
    But Vth at the OTA input will be much lower, is it what sets a lower limit
    to Ra?
    Ron
  2. I think the thing that limits how low Ra can go is S/N ratio.
    At the end of the day, Rin/Ra is a pot-down and is it desirable
    to have at least 50 or 100mV pk across Ra.
  3. R. G.
    R. G. Guest
    So I was not so far from the truth after all!
    Thanks!
    Ron
