Copied Win98SE from HD1 to HD2.
Internet useage fast on HD1, slow on HD2.
Slow due to massive swapping (ie: "virtual memory").
Took 60 seconds to write this message; swapping during entry of text.
How can i find source and fix it?
Thanks.
You haven't said what the MOBO, CPU or OS is, nor how much of what kind
of RAM..
The MOBO matters, because it carries the I/O interface for the HDs. The
OS matters, because Billy never was consistent in his ways and means.
Constant swapping usually points to lack of RAM or so many windows/apps
open that the same result occurs.
Also, copying large single files is different than copying small files.
So if you copied an ISO image file, you will get different numbers than
copying the 98SE archive as it appears on the disc, in the form of
hundreds of small (relatively) files
To get an indicator as to whether or not it is related to your
individual system hardware constraints, you should boot a Knoppix 5.1.1
Live boot disc. That gets you into Linux (or get a newer live distro
that is similar.
Set your drives to read/write mode, and do the copy, noting the speed.
That way, you can decide whether your hardware choices, or Billy are to
blame.
