Spehro Pefhany said:
Try *search* on such a file. I'll bet you'll find that the scanned
image is overlayed over an uncorrected OCR file created by Adobe
Capture. I don't think it's anything to do with Google.
Darn it, Speff, can't you wait til I get my chores done
I mentioned searching these files for text strings doesn't work. It tries
but quits instantly with no results.
Looking for an example, I tried searching google for a pdf article that I
downloaded long ago: Elaine Balliew, "The Challenge of Testing ADSL
Modems", Evaluation Engineering, October 1998. The copy I have is
definitely scanned with no text at all. Unfortunately, the only copy left
on the web is a text version stripped of all images. (Not that they were
that important.)
http://www.evaluationengineering.com/archive/articles/1098adsl.htm
So I'll never know why I downloaded the article - whether it was her wit
and charm, or the results of a google search, or if it was simply linked in
another long lost article
Anyway, I should never use google until all the dishes are washed and
everything is put away. it is simply too easy to get lost in very
interesting pages that you never seem to hit when you have lots of time to
spend. Here's one that might interest hams - low noise single-signal direct
conversion receivers
http://lekstutis.com/Artie/Ham/Projects/RT2.html
Lots of good links at the bottom, including one to Analog Devices AN-741,
"Little Known Characteristics of Phase Noise". Of course the link doesn't
work anymore - ADI has gone nuts with their file naming conventions.
Instead of simply calling it AN741.pdf, the file is now
http://www.analog.com/UploadedFiles/Application_Notes/54275316215330254506699244016AN741_0.pdf
Safely tucked away while I do the dishes...
Best regards,
Spehro Pefhany
Regards,
Mike Monett
