D
Don Y
Apologies as this isn't strictly on-topic. But, figured
*some* folks here could provide hints or pointers to other
forum...
I rescued a handheld scanner with some battery issues.
Now that it's working, it seems an interesting "toy"
to add to my bug out bag. (I don't have much interest
in listening to that sort of sporadic chatter on a
daily basis!)
But, I'm clueless as to the most *practical* way of
"programming" it. To be clear, I understand how to get
the parameters *into* it; rather, I'm curious as to the
best way to map those frequencies onto the scanning
order, etc.
The device has 10 groups of 10 channel assignments.
The first of each can be treated as a "priority"
channel (there is a mode that gives preference to
monitoring these above the others). Entire groups
can be (easily) enabled/disabled. And, individual
channels can be disabled (though a bit more work to
do this for many channels).
After a bit of thought *imagining* how it might be
most useful in an emergency, I think the best
approach is to group similar services (from different
municipalities, etc.) into each group. E.g., fire
in group 1, police in group 2, etc. So, in a
given geographical region, you would tend (??) to just
be able to pick up one set of services -- and, they would
be distributed across multiple groups. This would allow
you to easily disable that particular service without
affecting other services from that municipality
(e.g., wanting to listen to the police chatter without
being distracted by activity on the fire channel(s)).
Since there often are several frequencies for each
service, you could assign N groups for police traffic,
M others for fire, etc. This would afford you the
same sort of easy "gating" for those individual
channels -- instead of having them compete with each
other in the same *group*.
Having neighboring municipalities also present in
these same groups (but "out of broadcast range?")
would allow you to migrate with the device picking up
the *local* services as you move between jurisdictions
(without having to manually reprogram or enable/disable
new groups for each locality).
[Remember, this sits in my BoB, not on my desk!]
Any hams or "casual listeners" who can comment on the
utility of various approaches to this?
Thanks!
forum...
daily basis!)
order, etc.
Thanks!
