John Popelish said:
It takes more torque to turn the generator when more electrical energy is
being consumed. This torque is a bit like having the brakes lightly
depressed while driving down the road. The larger the electrical load,
the more the "brake" drags. This drag is more significant for a small
engine car than it is for a much heavier vehicle. For one that gets 30
miles per gallon, I suspect headlights cost you about 1 mile per gallon.
[removed comp.dsp from newsgroups]
You can probably figure the headlights to be roughly 200 watts, based on a
20 ampere fuse for the circuit at 12 VDC. This is about 1/4 HP. An
economical vehicle requires something like 10 HP on average, so I would
expect about a 3% drop in fuel economy, which would be 1 MPG if you get 30
MPG. YMMV
There may be a slight regen effect when going downhill, adding to the
compression braking effect, and the maximum charge current is somewhere
between 30 and 70 amps (about 1 HP). It might be possible to tweak the
charger circuit to engage only when the brake pedal is touched (or when the
battery drops below about 80% charge).
I saw an article on-line about adding an additional, larger motor/generator
to the motor belt system, with a separate battery bank and regen drive
circuit. It could possibly provide a good portion of the 10 HP or so needed
for normal driving, and instantly convert your gas guzzler into a higher
performance and more fuel efficient hybrid!
Paul
