Have you checked your alternator output. I've owned two 1981 CB750F models
and both had alternator problems. One I bought new and the one I still
have I bought in 1999. Both had under 6000 miles on them when one had a
short in the rotor and the one I have has a short in the stator. I can't
buy a new stator, discontinued. But I am thinking of having a place that
rewinds small motors and all sorts of things give it a try. One thing is
the 750 motor needs 13.8 volts or it will sputter and spit. However it
wouldn't cause it to die unless the battery was down and I don't think
this is your case. But check the output voltage none the less.
Well I can try unplugging the alternator and running it in rain the
next time it rains. It will start and run without an alternator. I
could see how noise on the battery could cause the trigger point of
the transistor switch to shift and cause a misfire.
This one did have a shorted rotor. I took it out and rewound it and
added an expanded scale voltmeter to watch it. No amount of water in
the alternator housing will cause the problem when it is stationary,
but it is easy enough to unplug so the next time it rains I'll try
that.
Actually you can buy rotors both rewound with a core charge, and brand
new for about the same cost ~$70 last time I checked. Place over in
England is manufacturing them and with shipping the cost was
comparable to buying one rewound in the US. I had a quote of $300+
from the Honda shop so spent $50 on a 6# spool of 22 AWG magnet wire
before I discovered I could get a new one. My rewind works well.
There's a little bit of run-out because the slip rings are a little
crooked but it has been running fine that way. There's still enough
left over magnet wire to wind several more (takes about 12 ounces of
wire for a rotor)
I also found a source for a new stator for it for a few hundred
dollars. I don't need a stator though - and it looks easier to rewind
than the rotor I already did.
That rewinding stuff isn't that tricky. Stators are wound on formers
external to the poles then put in place and epoxied in. Rotors are
more hassle - take apart the pole halves with a large gear puller, and
scrape out or unwind the wire.
I have used two techniques for the coils - a bobbin made of very thin
PCB material and soldered together then just insulate it and fill it
with wire brushing on epoxy as you go (the bobbin could be almost
anything including cardboard or tin can material - just has to be
strong enough to hang together long enough to mount and epoxy it in,
and thin and insulated.
Technique two is to just wind a "self supporting coil." Build/make a
two part wood mandrel of about the right size, then cover the wood
with Teflon plumbers tape (for a mold release agent). For the sides I
use a pair of polyethylene can covers like one sees on Planter's
Peanuts, cut an undersize hole and slip it on the mandrel. Brush it
with a light coating of machine oil (mold release again), then just
paint the core with epoxy and wind adding epoxy after each layer or
two (the epoxy creeps out between the lower windings so it isn't
necessary to do after each layer). Let set then pry it off the
mandrel. I add a layer of cloth soaked in epoxy to the pole pieces to
keep it in place and protect the sides. Only caveat is to carefully
route the wires to the slip ring connections along the pole so they
aren't allowed to move and epoxy in place.
My alternator output is more like 14.4 volts, but it always has been.
