W
w_tom
If speculating, then at least put some numbers to that
'massive stress'. Filament must be severely damaged for that
gentle 'power-on' stress to break it. Often that stress is so
minimal that the filament instead fails by vaporizing the
little that remains at the hot spot. A far more severe stress
is people walking on the floor above.
Filament gets real hot; therefore it must be high stress?
Without numbers to define stress, then stress is only wild
speculation. The point of my initial post that resulted in so
much emotion: They did not know. They speculated. They did
not first consult industry sources, numbers, or citations.
They just speculated. Speculation creates junk science
reasoning.
Once the filament is so badly damaged, then dark spots
appear inside the glass envelope. Then either the bulb fails
on power on OR fails during operation some hours later. My
last bulb failed some hour after power on. Most never notice
failure during operation but always notice the failure on
power on. Just another reason why observation is not a valid
fact. But again, damage that causes failure is defined by ...
hours of operation.
Numbers, equations, citations, etc were provided
previously. If you think power on causes so much stress,
well, where are both numbers and citations? Wild speculation
and no numbers are symptoms of junk science. Please don't
make that mistake. Enough junk science reasoning (followed by
emotional outbursts when bluntly confronted) has already been
posted in this discussion.
You are assuming the seven times or tens times current on
power up is destructive. This assumption is answered in
another post.
reasoning.
hours of operation.
another post.
