Well,plenty of replies for incandescent bulbs... any replies for compact
flouresents? I know that I shoulden't be putting a flouresent lamp in
the toilets or cupboards, but what about tha hall? the bathroom with a
big family? I hear the "15 minute" rule regularily, but why 15 minutes
and what are the mechanism that reduce life?
There is no one-size-fits-all rule here as in how many minutes does a
compact fluorescent have to stay off or else it would have been more
economical to leave it on.
For one reason, different wattages cost different amounts per minute to
operate, while the cost of the lamp does not vary much with wattage.
Also, some suffer more damage from starting than others.
As for why damage from starting? When the filaments (electrodes) are
not at normal running temperature, the emissive material on them is not
working fully. That results in a higher electric field (voltage gradient)
around the filaments when they are working as cathodes, and positive ions
will bombard the filaments with greater force than normal - and dislodge
atoms of the coating material.
Some are true instant start, which has the lamp operating before the
filaments are warmed up. The lamp may be slightly dimmer while the
filaments are warming up due to higher voltage drop until the
filaments are supporting a "thermionic arc". Some are similar to what is
called "rapid start" with standard fluorescents in the USA, where the lamp
starts glowing while the filaments are being warmed up, but the lamp is
fully on when the filaments get close to normal operating temperature.
Some are "programmed start", where the arc is struck after the filaments
are warmed up. Some have glow switch starting, and usually blink a few
times while starting.
Glow switch ones are the worst for a large number of starts, instant
start is second worst, and program start is the best in terms of damage to
a fluorescent lamp due to starting.
And I have also heard that handeling the glass part will reduce the
number of cycles before the lamp dies... but why?
I have not heard that one. The closest to that I heard is that halogen
bulbs do not like skin oil, salts, ash, alkalis, etc. The compact quartz
bulb/capsule gets extremely hot and is under high stress from high
pressure of the fill gas. Salts and alkalis (including from ash) leach
into quartz at that temperature, causing weak spots and/or stressed spots.
- Don Klipstein (
[email protected])
