Jonathan said:
Thanks. I was also going to add some peer-reviewed papers, too. But
the criticism was disingenuous and you've pointed out enough for it.
Jon
I said the major models I'd reviewed don't model dynamic vegetation.
Since you've called me a liar, please find excerpts below from
the descriptions furnished by the agencies themselves.
Neither the NCAR, NOAA, Max Planck, NASA/Goddard, nor Hadley models
model changes in vegetation or ice sheets. As I said.
Those are the only five I checked today--maybe you can find a
better one.
All the models I've examined include an explicit CO2 sensitivity
constant, specifying temp. rise for a given CO2 increase. Which
is to say, the models do not model or predict temp. rise, they
take this assumption as a given, then project the amount of warming
based on the rise in CO2 they've programmed.
Those are just a few of their simplifications and assumptions.
There are others, such as clouds. Maybe you'd like to scare up
some peer-reviewed data on the performance of their cloud models
as compared to actual observations?
Cheers,
James Arthur
CCSM3 (National Center for Atmospheric Research)
http://www-pcmdi.llnl.gov/ipcc/model_documentation/CCSM3.htm
II. Besides atmosphere, ocean, sea ice, and prescription of
land/vegetated surface, what can be included (interactively) and was
it active in the model version that produced output stored in the
PCMDI database?
A. atmospheric chemistry?
Qualified yes: two processes are active:
(1. Modification to GHG concentrations by chemical processes; and
(2. Conversion of SO2 and DMS to sulfate aerosols (the sulfur cycle).
B. interactive biogeochemistry?
No
C. what aerosols and are indirect effects modeled?
No indirect forcing effects are included.
The semi-direct effect (reduction in cloud amount by aerosol heating) is
included.
Aerosol species included:
(1. Sulfates
(2. Black and organic carbon
(3. Sea salt
(4. Soil dust
(5. Stratospheric volcanic aerosols
D. dynamic vegetation?
No
E. ice-sheets?
No (glaciers are specified, but there are no dynamic ice sheets)
GFDL-cm2 (Geophysical Fluid Dynamics Laboratory NOAA)
http://www-pcmdi.llnl.gov/ipcc/model_documentation/GFDL-cm2.htm
land/vegetated surface, what can be included (interactively) and was it
active in the model version that produced output stored in the PCMDI
database?
A. atmospheric chemistry? Not yet
B. interactive biogeochemistry? Not yet
C. what aerosols and are indirect effects modeled? No indirect yet
Aerosols – Organic and black carbon, dust (constant in historical/future
runs), sulphate, and sea salt.
D. dynamic vegetation? Not yet
E. ice-sheets? No
ECHAM5/MPI-OM (Max Planck Institute for Meteorology)
http://www-pcmdi.llnl.gov/ipcc/model_documentation/ECHAM5_MPI-OM.htm
database?
1. atmospheric chemistry? Yes (not active)
2. interactive biogeochemistry? Yes (not active)
3. what aerosols and are indirect effects modeled? In the IPCC runs
done so far, sulfate aerosol is prescribed (direct and first indirect
effect). An experiment with interactive aerosols is in progress (A1B)
including the first and second indirect effects as well as the
semi-direct effect.
4. dynamic vegetation? No
5. ice-sheets? No
GISS-AOM (NASA Goddard Institute for Space Studies (NASA/GISS))
http://www-pcmdi.llnl.gov/ipcc/model_documentation/GISS-AOM.htm
II. What can be included (interactively) and was it active in the model
version that produced output stored in the PCMDI database?
A. Atmospheric chemistry: no
B. Interactive biogeochemistry: no
C. Aerosols: Boucher's monthly-decade sulfate burden (mg/m^2)
(downloaded from PCMDI web site) was converted to an
optical depth by global coefficient [.030 (m^2/mg)]
and treated as tropospheric sulfate aerosols with
particular vertical distribution;
indirect effects were not separately modeled
D. Dynamic vegetation: no
E. Ice sheets: nothing other than that covered under IV. D. 9.
UKMO-HadCM3 (Hadley Centre for Climate Prediction and Research)
http://www-pcmdi.llnl.gov/ipcc/model_documentation/HadCM3.htm
database?
1. atmospheric chemistry? YES. Sulphate aerosols produced by
oxidation of SO2. Oxidants concentrations provided by running offline
the STOCHEM model [OH, H2O2 and HO2]).
2. interactive biogeochemistry? NO
3. what aerosols and are indirect effects modeled? Three modes of
sulfates aerosols (Aitken, accumulation and dissolved in cloud droplets)
with explicit parameterizations of transfers between the different
modes. SO2 and DMS are injected at appropriate levels. The direct
radiative effect from scattering and absorption is taken into account.
The indirect effect was implemented by prescribing cloud changes
calculated by offline models (see Johns et al., 2003, Appendix A for
more details)
4. dynamic vegetation? NO
5. ice-sheets? NO
