John Popelish
Eeyore said:Absence of pre-ignition allows a higher compression ratio which in turn boosts
efficiency ( Carnot Cycle IIRC ).
Exactly. If your engine does not have a high enough
compression ratio to make use of pre-ignition resistant
potential of the fuel, that potential is wasted. And the
additives that are put into low octane rated fuel to raise
its octane rating makes the fuel more polluting both to the
outside environment and to your engine's internals. That
premium gasoline is not better, in general, but better only
in one respect and worse in almost every other respect, is a
BIG secret that is never brought out in gasoline
advertising. They always imply that if you love your car,
you will treat it to premium. What a profit center. Add a
couple cents worth of anti-knock additive and add 20 cents a
gallon to the price.
