Jim Thompson
Why not buy a blank plate and drill a few holes?
John
Watson beat to that suggestion. I think it'll work, just a little
more difficult to fish the coax through.
...Jim Thompson
John
I really doubt it, NEC frowns upon signaling wires being grouped
with power wires in a receptical box. They like to see the two
run at least 1 foot apart in walls.
Jim said:If you put a divider in the box, then the box will be in violation forLord said:And you would still be in violation of multiple electrical codes.
Of that, I am certain but that is what the home owner wanted and for the
same reason as Jim. I am certain there will be no short as I installed a
divider in the box.
wire fill size. [snip]
-Chuck
That apparently is not correct. I HAVE found plastic outlet boxes
with a molded-in divider, for mixed AC and "low voltage devices".
...Jim Thompson
divider in the box.
-Chuck
...Jim Thompson
If the box was NEC and UL approved with the divider, then it would be
ok. It is not ok to just wing it and put your own divider in the box.
Box dimensions for the line side have a wire fill requirement that for
#14 guage wire is 2 cuin for the line, 2 for the neutral, and 2 for all
of the grounds, 4 cuin for the receptical, and 2 cuin for an internal clamp.
A typical box with one duplex receptical whose circuit ends in the box
needs to be a minimum of 12 cuin in volume. A boxe's size is the size it
is NEC rated for, not necessarily the exact volume... you are not allowed
to make your own.
It is the testing part that is missing.
-Chuck
Lord said:Of that, I am certain but that is what the home owner wanted and for the
divider in the box.
Jim said:I've decided to go with Watson's suggestion.
...Jim Thompson
You can get stainless steel plates that look better than the cheesyThat's a good idea, Watson! Three easily drilled holes, one for the
coax, two to mount the faceplate into plastic anchors.
Problem solved!
It should work ok, it is the one that all of the cable installers
use.
-Chuck
Hello Jim,
almond plastic. But whatever you do make sure it doesn't get full sun.
Else it'll cook out the coax in no time. We could not avoid that for the
eastern deck.
So I hacked a gray outdoor wall outlet cover. An angle
F-connector makes sure it can close even when the TV cable is in there.
But the best was when I bought a TV modulator after finishing the
centralized TV distribution. Now we can watch Andy Griffith everywhere
just by selecting channel 69. What's missing is an IR-RF-IR feedback to
the VCR for skipping commercials.
Regards, Joerg
Buy some white RG6 and lay it along the baseboard. There are clipsCould be ;-)
Surfing I've found a plastic box with a partition rated for a low
voltage device plus an AC device... box, but no components.
I may just have to bite the bullet and cut another hole, but it's an
outside wall... thick stucco, not fun, or easy to be neat, to chisel
out :-(
...Jim Thompson
I just remember:
A friend of mine had the silly idea to mux hot and cold water in the same
copper pipe to get warm water into a small room without installing a second
pipe
I just remember:
pipe
-Chuck
They even whine if you mix power and fiber......
Do you think the boys at the local consumer electronics storeGo to a store that sells tv's and has a large number of them on display.
Look at what they're plugged into. What I'm talking about is a raceway thats
split in the middle...power on one side and coax on the other. Its about 2
in wide by 1 inch tall and comes in up to 10 ft lengths.If it will work for
waht you want to do...it can be gotten from any electrical supply house..
Hope it helps
use.
actually get inspections of their installations done?
What does that tell you about the actual conformance of such
set-ups? Sure it works... so what? Doesn't mean that it is legal.
For Pete's sake: we're electrical engineers. Why would we care if an
outlet is "legal"?
Michael A. Terrell said:And you got both NEMA and UL approval to make the divider?
Michael A. Terrell
Central Florida
