K
krw
**** off, KeithStain.
If you'll go look up the lyrics, you'll see that they fit better than
you might imagine.
You are owned.
BTW, Dimbulb, how is mom? Still have that headache?
you might imagine.
You are owned.
Joerg said:Well, for me the first avenue is always to contact the comapny that sold
me the merchandise. Give them a chance. That would be Dell, and so far
they were pretty responsive. Foxconn will be next but I won't get my
hopes up.
krw said:I see you finally found one of mommy's socks that fit.
Joerg said:It's not THE phoenix Award BIOS v1.0.3, It is the:
<insert MOBO make and model name here> BIOS v 1.0.3, provided by the
Award Bios vendor. The versions are MOBO specific, and IF Dell comes out
with another, it will increment. Phoenix is merely the provider. Dell
authors the code.
So Dell wrote the BIOS? Interesting. I thought they were migrating
farther away from the design process. At least they seem to be doing
that with hardware.
Actually, the entire MOBO is likely made FOR Dell by a popular MOBO
maker.
Yes, by Foxconn.
There's your solution. Examine the form factor of the MOBO, and BUY a
cheap MOBO that fits it, that carries the floppy utilization capacity you
need! :-] Bet you could find one for less than $50.
Either that or get a BIOS for a similar G33 Foxconn mobo that includes
the drive support I need. If the HW is on the mobo it can't be rocket
science to access it. Someone said that Linux bypasses the BIOS and see
all the stuff that's on the mobo but was blocked out by the BIOS that
came with it. Maybe there is a kludge for Windows that does that.
My curiosity tells me that I want to figure this out some day and not
take the easy road of swapping the mobo. But not right now, no time.
ChairmanOfTheBored said:The only question would then be whether or not they had specs there for
there older no longer sold or supported cards.
Since SCSI and floppy are not the same bus, it doesn't make much sense
that they would carry it on their generally component packed cards.
hopes up. IME the responsiveness of Chinese companies is, ahem, sub-par.
Unless you happen to be the cousin twice-removed of the brother-in-law
of the chief engineer there. Taiwanese companies were usually very
different in that respect. I remember a long time ago when I contacted
Tseng Labs (remember them?) because I needed to address their graphics
chip directly out of an ultrasound scan converter. Then next day the
phone rang and a woman asked whether she could help. Turns out she was
one of the designers of that chip, knew it inside out and answered every
single question about it and actually gave me some valuable info that
wasn't in the datasheet.
The reason for this exercise is not to save a buck but to learn and also
to see whether a system like this could be used in some client
applications. They often require XP as the OS just like I do and legacy
support is also important. Piecing together a system isn't an option and
usually it has to come from places like HP or Dell.
Baron said:Joerg said:ChairmanOfTheBored wrote:
On Fri, 12 Oct 2007 09:33:35 -0700, Joerg
It's the
Phoenix AwardBIOS 1.0.3. I am very surprised that such legacy
features were chopped off.
out
Dell authors the code.
that with hardware.
maker.
Yes, by Foxconn.
BUY a
you
see all the stuff that's on the mobo but was blocked out by the BIOS
that came with it. Maybe there is a kludge for Windows that does that.
Joerg, Don't mess about! Try a Linux Live CD. You could be pleasantly
surprised.
Much of my stuff doesn't work under Linux and some supposedly not even
in a VM.
YD said:Late at night, by candle light, Joerg
Much of my stuff doesn't work under Linux and some supposedly not evenBaron said:Joerg wrote:
It's the
out
that with hardware.
maker.
Yes, by Foxconn.
BUY a
you
surprised.
in a VM.
If it lets you mount both the 5 1/4" drive and the NTFS partition you
can copy off the files. Then just boot back into Windows.
Michael said:I wonder if the chip for the external USB floppy drive will support
either 5.25" drive? It would be a niche market, but I'm sure that there
would be some sales. Either that, or start a reasonably priced data
conversion service.
New 5.25" drives are becoming scarce, but I have about 100 good, used
360 KB and 1.2 MB drives, along with computers that support them. If I
put a clean install of Windows 98 SE, or ME on one I could burn a CDROM
or copy their files to a USB stick, one floppy per folder. That way
they could make as many 1.44 floppies as they want, or just keep it on
the media. A few bucks per disk, plus the media and shipping costs.
BTW, I have about 1000 new Maxell 1.44 MB floppies on hand that I
could use.
I am working to recover the bookkeeping data for a local non profit,
after their Windows 95 computer died. They made the mistake of not
replacing the computer, because it was only used a few hours a month.
When the power supply started acting up, they just kept using it, even
when it took them a half hour to get it to power up.
I would recommend that you tell your customers that any old media be
converted while it's still readable. Some 5.25" floppies become
unreadable with age. Programs like the original Norton Disk Doctor can
recover a lot of files, but it takes hours, or days. If they are too
far gone, you have to go the expensive route of commercial data recovery
services. I wonder how much it would help, if I added another gain
stage to the head preamp circuit, for those failing disks?
Eeyore said:Didn't you say the Dell Mobo you have is a stripped down version of another one
they make ? It's entirely possible that the 'full fat' BIOS will work on the
Dell mobo. It's likely to be alot easier to get a copy of that (probably as a
BIOS update).
No, dumbass. A cast case is used in many, but NOT the seagate
drives.
And the casting is MINIMALLY machined on the boss for the spindle
motor, and the locations for mounting it into the machining center,
and aligning the PCB so the rear connectors are all correctly
located, you stupid ****.
The seagate case is FULLY machined, and it is done so from a
billet,
not a casting.
Maybe one day, you will know the difference, you goddamned retard.
It's the
by the
comes out
provider. Dell authors the code.
migrating farther away from the design process. At least they
seem to be doing that with hardware.
MOBO
maker.
Yes, by Foxconn.
and BUY a
capacity you
includes the drive support I need. If the HW is on the mobo it
can't be rocket science to access it. Someone said that Linux
bypasses the BIOS and see all the stuff that's on the mobo but
was blocked out by the BIOS that came with it. Maybe there is a
not take the easy road of swapping the mobo. But not right now,
no time.
pleasantly surprised.
even in a VM.
Bullshit. I'll bet that it works under DOSBox, or QEMU either one,
whether from within DOS, Windows, Linux, or even on a MAC, as the
app has no way of knowing what it is running under.
Joerg said:Won't help much because while the other mobos do have legacy ports they
still don't list 5-1/4" availability.
YD wrote: ....
Thanks! That is a good idea. Would that be the Knoppix CD people are
always talking about?
I have a cheap (computer show purchase)USB floppy drive reader/writeMichael said:I wonder if the chip for the external USB floppy drive will support
conversion service.
could use.
ChairmanOfTheBored [email protected] posted to
sci.electronics.design:
It's the
by the
comes out
MOBO
maker.
Yes, by Foxconn.
and BUY a
capacity you
no time.
even in a VM.
Utter retarded horseshit. Every one of those OSs has documented calls
to ask just what OS and version is installed.
Jamie said:I have a cheap (computer show purchase)USB floppy drive reader/write
that simply plugs into the port of an existing drive. it supports the
5.25 drives. You simply go into it's software and specify the drive type
that is connected to it. It does not auto detect the drive type.
If any one is interested, I would have to look at the make and model
of it at work tomorrow.
It's the
out
that with hardware.
maker.
Yes, by Foxconn.
BUY a
you
surprised.
in a VM.
