OT Brother 2240 printer wierd problem
E
ehsjr
My Brother 2240 printer warned of low toner, & eventually quit when
the toner was empty. Staples would happily sell me a new toner
cartridge for 45 dollars - and they had the entire printer for sale
at 50 dollars. I bought the printer.
All good so far. For the repair, I took the toner & drum assembly
from the new 2240 and put it in the old 2240. No good - it would
not work. It goes in just fine, but the old 2240 would not work.
What the heck is going on with that??? Whyintheheck wouldn't that
new toner/drum assembly work in the old printer??? Maybe there's
something you have to do when installing a new drum & toner assembly
that I don't know about. :-(
To complete the story:
I installed the new printer with the toner & drum assembly that
came with it, & it works fine.
I ordered a toner refill kit and refilled the old toner cartridge.
The old printer now works fine, too.
Ed
M
Martin Riddle
Ed
The brothers need to have the Drum counter reset. I don’t think there is
any counter for the toner.
Cheers
S
Spehro Pefhany
Ed
Had a similar problem with a Samsung color printer- transfering an
alread-used toner cartridge from one printer to another of the same
type would not work. This could be done easily with an EEPROM on the
printer cartridge, maybe to prevent refilled cartridges from being
sold.
Best regards,
Spehro Pefhany
E
ehsjr
Cheers
Thanks Martin, that explains it. Mystery solved! :)
Regarding the toner counter - you are right, there isn't one. They
use a mechanically driven "flag gear" that rotates a tiny bit every
time a page is printed, apparently regardless of how much toner is
used for printing that page. When the gear rotation eventually
reaches 180 degrees that signals that the toner is empty - again,
apparently with no regard for how much toner remains. When you
refill the toner for the first time you need to install a different
flag gear. Subsequent refills do not require replacing that flag gear.
Ed
E
ehsjr
sold.
Best regards,
Spehro Pefhany
Thanks Spehro. Maybe the Samsung has a procedure similar to the
drum reset that Martin mentioned for the Brother.
The Brother does have a mechanism to limit the life of the toner that
is installed in the printer when you first buy it. They have a one
time use "flag gear" on the original toner that signals toner empty
after X amount of printing.
If you refill the toner cartridge you must replace that flag gear
with one of a different design. That allows more printing before
signaling toner empty, and need not be replaced for subsequent
refills.
Ed
