oscilloscope trace`
Discussion in 'Troubleshooting and Repair' started by Dan_68, Sep 6, 2012.
  1. Dan_68
    Dan_68
    36
    May 1, 2011
    Hi all,
    I have an old oscilloscope which still works fine the only problem is the line doesnt go horizontal, even twisting the adjuster it comes close but it just isnt enough. Does anyone know what caused this and more importantly how to fix it.
  2. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    With my knowledge of CRT screens it is more likely than not a capacitor issue, most likely the one tied to the adjuster control
    If you are comfortable with it, open it up and look for any bulging/blown capacitors, and try to find the ones near the adjuster knob and measure the resistor there as well.
    Take some pictures too
    What make/model is it?
  3. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Try rotating the oscilloscope (looking down on it from above, rotate it clockwise or anticlockwise slowly) and seeing whether the trace can be made horizontal. The trace is affected by the Earth's magnetic field. You might have to have the scope facing in a different direction.
    You can also try degaussing everything metal, including inside the scope, using a picture tube degausser (a tape head demagnetizer might work but may not be powerful enough).
