I've been in the TV business 26 yrs and am still using a 1979 model
scope 30mhz Leader. Is there a big advantage to these new digital
scopes? I've also got a Fluke 123 scopemeter that's 20mhz that I'm not
thrilled with. Any recommendations for a TV guy who also dabbles in
pinball repair that uses digital timing on ICs. I can't make any sense
of any digital signals with the old scope or the Fluke.
Based on your stated applications, you could get a heck of a lot
of performance out of one of the older Tektronix 7000 series
instruments.
I would suggest a 7603 mainframe, a 7B53 timebase, and a 7A26
vertical plug-in. All should be available from ham swap meets or greed-
bay at pretty reasonable prices. In fact, I'd be surprised if the whole
thing cost you more than $100-$150. This setup will be good from DC to
at least 100MHz.
If you need higher bandwidth to grow with as your needs change, I
would suggest a 7704 (250MHz), 7904 (500MHz), or (if you really need
gigahertz bandwidth) a 7104 mainframe, coupled with appropriate plug-
ins.
If you would like something 'luggable,' yet versatile, I would
suggest a 465 or 475 series portable 'scope, preferably with the
multimeter option.
You may also want to look into a 7D20 digitizer. They were
practically made for the 7603.
Happy hunting. Don't forget decent probes!
Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute.
(Known to some as Bruce Lane, ARS KC7GR,
kyrrin (a/t) bluefeathertech[d=o=t]calm --
www.bluefeathertech.com
"If Salvador Dali had owned a computer, would it have been equipped
with surreal ports?"
