H
Helmut Sennewald
john said:Hi,
Is BNC cable is appropiate cable to make oscilloscope readings or
oscilloscope probes?
Hello John,
It depends on your requirement. It would be ok for signals up to 100kHz.
The disadvantage would be the higher capacitance of the normal coaxial
cable. Probe cables have only half the capacitance of 50Ohm coaxial
cables.
My co-worker is insisting that BNC Cable is more
shielded than the probes?
I don't agree.
I suspect that its not all about shielding
only. There is a reason that probes exsists.
The most important thing is the distributed series resistance of the
inner conductor. A value of 100 to 200 Ohm per meter gives the
best pulse performance. If you would make a 10:1 probe using
a normal coaxial cable, you would have nearly 100% overshoot
for rise times below ten nanoseconds.
Best regards,
Helmut
