Oscilloscope primer rec?
Discussion in 'Electronic Basics' started by Eric R Snow, Oct 4, 2005.
  1. Eric R Snow
    Eric R Snow Guest
    Today I used an oscilloscope properly for the first time. It is a
    Tektronix 465B. The manual for this 'scope isn't that helpful when you
    aren't familiar with the terms of the 'scope or what it measures. So,
    I would like, please, to get a recommendation(s) for a book aimed at
    beginners like myself.
    Thank You,
    Eric R Snow,
    E T Precision Machine
  2. Chris
    Chris Guest
    Hi, Eric. Congratulations. The 465B is a great scope. It's easy to
    use, easy to repair, and it's a great one to learn on.
    By far the best online resource for learning about scopes is from
    Tektronix, called "The XYZs of Oscilloscopes". It's available in .pdf
    format from Tektronix:
    http://www.tek.com/Measurement/cgi-...rement/App_Notes/XYZs/&FrameSet=oscilloscopes
    http://tinyurl.com/9m267
    Once you've got that intro, the manual will make a lot more sense.
    Good luck
    Chris
  3. w2aew
    w2aew Guest
    Ditto on the response recommending the Tek note (XYZ's...)
    Also, check out a few of these links (found with google):
    http://www.ee.usyd.edu.au/tutorials_online/topics/labintro/cro.html
    http://web.telia.com/~u85920178/scope/osc-0.htm
    http://www.williamson-labs.com/scope-main.htm
    http://en.wikipedia.org/wiki/Oscilloscope
    ....etc.
  4. tekamn
    tekamn Guest
    Well, and because the OP mentioned he already has the manual: The
    section "operation" has a couple of good measurement examples.
    hth,
    Andreas
