oscilloscope output through serial port
Discussion in 'Electronic Equipment' started by karina, Nov 7, 2004.
  1. karina
    karina Guest
    Hi!
    I'm using Tektronix TSD220 oscilloscope for recording Video and Audio
    signals from DVD playback. I'm interested in calculating the Delta
    between Audio and Video signals. I would like to connect the
    oscilloscope to the PC and to record the oscilloscope output to a file
    (of any kind). Is this thing possible? Which software is needed for
    this aim? Which configurations?
    THanks, Karin
  2. I'm using Tektronix TSD220 oscilloscope for recording Video and Audio
    You need the interface module that goes in the port on the back. I
    don't think you can dump raw ADC data out that port, though - it is
    intended for trace printouts.
  3. TekMan
    TekMan Guest
    You are right: There is no way to dump the raw ADC data. Even the
    IEEE488 Module does not offer enough bandwith.
    Update rate is approx. 30 waveforms/s, so you are far from realtime
    application.
    hth,
    Andreas
