Hi all. I'm new to this forum, and I come with a problem. I got for free a broken oscilloscope and it's rather unknown, made in Germany in 1966 it seems, ofc it is a analog tube machine. First problem it had was with the switch-on pot, the switching part was broken so I did a direct circuit (temporary until I install a sepparate on/off switch somewhere) as the pot is still ok (pot for display intensity). After first fire-up the dot showed no problems, I attached a 100hz sine wave generated by my computer through a M-Audio Fast Track Pro soundcard so everything ok on this end. Attached the probe and sinewave came up on the tube display. The problem is that the upper part of the sinewave is "clipped", first I suspected the soundcard but luckily I have (only for a few days) a digital portable scope (Velleman) that showed a perfect sinewave, same as triangular and rectangular. But my scope seems to clip the upper part, at least distort it. I forgot to mention, my machine is a RIM Rog 7A and I can't seem to find the manual/schematics anywhere but radiomuseum where I don't have an account (I would like to ask for anyone who could send me the manual/schematics for my scope, I would very much appreciate as I don't have the means/possibilities to pay for the membership there) And they seem to be the only ones who have it online. I could only check the tube heaters, and as well I tested about 2 or 3 of the 5 E88CC's on my (now laid out on a breadboard) tube amp as it uses an equivalent for input stage/PI stage, and they seemed ok. I also discovered that the problem might have a thermal character, as when I opened the case to check the transformer voltages I discovered that the transformer has 43-45 degrees C and in about 5 minutes the shape improved a bit. After I put the cover back on I checked the temp on transformer and it only rose for 1-2 degrees. But the shapes got distorted again after 5 min or so. I also changed a 100uF/25V electrolytic as it was bloated, I think there's another one there and I got 3 big ones as well, but they seemed ok, I measured with a DMM and are in spec (I realize it isn't the most conclusive test for caps but hey, least I could do anyway. no leakage at least).
I also attached pictures with case closed and case open, you will see what I mean. (last 2 pictures are taken with open case)
