already have a decent volt meter but I'm thinking of buying a cheap Oscilloscope as part of learning about design/build small circuits, micro-controllers(arduino), RC filters, small amplifiers, relay drivers...that kind of thing. ..I can't see into the future or know enough atm to choose..so that's where you guys come in...
my absolute max budget is $125 ..another option would be to buy something used..it might be 30 yrs old, but will have 2 channels and some nice spec ..been looking at hamegs, tektronics, gould, lg etc ..eg Tektronix 2215 60 Mhz Dual Ch Dual Timebase Oscilloscope...but I doubt I could make repairs if it goes down or is delivered faulty and also wonder if they are toxic somehow?
....so new but crap or old but good? ...here are some examples I found within my budget
Poor Man's Oscilloscope
not sure how much use this will be and would really prefer something separate from the pc but I'l include as it's the cheapest and has 2 channels....and some might think there's no point paying more
DSO Nano v2
spec could be better and uses battery ....but nice screen
DSO 082
good spec/features for the money but the screen looks small...some video in the link
HPS140 Handheld Pocket Oscilloscope
seems easy to use but overpriced for what you get ..uses battery
$10-$15
my soundcard spec:
Creative Sound Blaster X-Fi Xtreme Gamer
Interface Type: PCI
Signal Processor: Creative X-Fi Xtreme Fidelity
Sound Output Mode: 7.1 channel surround
DAC Data Width: 24-bit
Sample Rate: 8 kHz (min) - 192 kHz (max)
Signal-To-Noise Ratio: 109 dB
DSO Nano v2
$100
Full Color 2.8" TFT LCD 65K 320×240
80Vpp (by ×1 probe)
0 - 1MHz
10Hz~1MHz square wave
1Msps 12Bits
4096 Point
1uS/Div~10S/Div
10mV/Div~10V/Div (with ×1
0.5V/Div~100V/Div (with ×10
500K
Auto, Normal, Single, None, Scan and Fit
Rising/Falling edge/level trigger
Trig level adjustable with indicator
Trig sensitivity adjustable with indicator
Auto measurement: frequency, cycle time, duty cycle,
peak voltage, RMS voltage, Average voltage and DC voltage
Precise vertical measurement with markers
Precise horizontal measurement with markers
Hold/Run
Micro SD card
as SD card reader
USB
500mAh 3.7V Lithium battery / USB
DSO 082
$110
Vertical
Number of Channel: One
Analog Bandwidth: 0 - 10MHz
Sensitivity: 10mV/Div -- 5V/Div
Resolution: 8-bit
Input Impedance: 1M ohm
Maximum Input voltage: 50Vpp (for 1X probe)
Coupling: DC, AC, GND
Horizontal
Max Real-time Sampling Rate: 50MSps
Timebase: 0.2us/Div - 10s/Div
Record Length: 2000 - 16000 points user selectable
Zoom-in: Up to 10X in HOLD mode
Run/Hold Modes: one button switchable
Trigger
Trigger Modes: Auto, Normal, Single
Trigger Types: Rising/falling edge
Trigger Sources: Internal/external
Trigger Position: Adjustable
Trig Point Indicator: Yes
Other Features
Save/Recall up to 4 captures
Screen image hardcopy
USB connection for data transfer and firmware upgrade
FFT with selectable length of 256, 512, or 1024 points and sampling rate from 1KSps to 50MSps
Rotary encoder for quick parameter setting
Display
2-inch 128 X 64 black-and-white dot-matrix LCD
Backlight ON/OFF control
Contrast adjustable
Power Supply
9V AC/DC power adapter
Supply voltage range: 8 - 12V
Supply Current: 300mA (LCD backlight ON, typical)
Reverse polarity and over-voltage protected
$125
bandwidth: up to 10 MHz (-3dB or -4dB at selected ranges)
input range: 1mV to 20V/division in 14 steps
input coupling: DC, AC and GND
real-time sample rate up to 40MS/s
AD resolution: 8 bits
time base: 250ns to 1h per division
auto set-up function (or manual)
probe x10 readout option
readouts: DC, AC+DC,True RMS, dBm, Vpp, Min-Max. (±2.5%)
audio power measurement from 2 to 32 ohms
hold & store function
time and Voltage markers readout
Max. 100Vp AC+DC
white LED backlight
operates on NiMH rechargeable battery pack (included)
operates up to 6 hours on one charge*
charging power supply: 9Vdc/200mA
for use on CLASS II pollution degree II installations
