Kevin Aylward said:
Not always. The relevant phrase is "conditionally stable systems". i.e.
stability is determined by the net encirclements around the minus 1
point. Indeed, *the* fundamental point, imo, of stability theory *is*
that systems with net positive feedback, and gain greater that one, can
be perfectly stable. It was for such strange behaviour that stability
theory was invented in the first place. If the greater than one gain at
0 degs was sufficient, why have a complicated theorem in the first
place.
This is interesting, I must confess I don't know much of stability
theory. When I hear this word I think in these terms: (amplitude)
bounded input implies (amplitude) bounded output. This brings, when we
consider lumped element circuits, to the requirement for the transfer
function to have no poles in the right half plane (with no concern
about their phase).
Coming to the feedback system, I've made a few simulations with an
amplifier and a delay line, connected such that they have a loop gain
greater than one. The delay line introduces a phase shift...and even
if strictly speaking we can't talk of poles and zeroes, I've noticed
that I get an infinitely growing output for any limited input, and for
any time delay.
This would bring me to the conclusion that, if I have a system giving
me an amplified (and time shifted, this is fundamental, it doesn't
work with static systems) replica of my input, which goes and sums
with it, then it doesn't matter about the phase with which it will sum
with the input: the result will always be an ever growing signal. That
is, the system is unstable.
This seems to be in contraddiction with what you say, but probably the
missing link between a *delay line* and a lumped element circuit phase
behavior is causing me problems...
Would you mind clarifying this? I would also be keen on reading some
good book on the subject. I hope you're not a state variable fanatic,
because this is exactly why I've never gone through with this theory.
I'm much more a Bode fan ;-)
Michele
