Oscillator circuit LC
Discussion in 'General Electronics Discussion' started by graemeian, Oct 2, 2014.
  1. graemeian
    graemeian
    13
    Oct 2, 2014
    I want to build a simple battery powered oscillator circuit that has an output frequency that follows w=sqrt(1/LC). I need to build an AC susceptometer. My goal is to build a circuit with an air core inductor. I want to monitor the frequency of the tank circuit and pass a sample into the coil. If the sample contains ferromagnetic impurities, the inductance increases and the frequency increases. We fabricated one in graduate school using a tunnel diode. However, tunnel diodes are hard to find.
    I would like to find something like a 555 chip and instead of changing R and C , I would like to include L. I would like to get a square wave output. I have frequency counters available. Any help would be appreciated.
    Thanks.
  2. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Hello and welcome to Electronics Point :)
    I'm not aware of any IC that's designed to make an LC circuit oscillate, though there are many circuits using op-amps and other devices.
    But can you start by telling us the frequency range that the circuit needs to operate over?
  3. graemeian
    graemeian
    13
    Oct 2, 2014
    The frequency range will be ~10K to 100K Hz. I could add more turns on the coil to reduce frequency. A typical counter should have no trouble counting 100K Hz.
  4. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    That's fine. Well, there are lots of ways to make an LC tank circuit oscillate. Check out this image search: http://www.google.com/search?q=lc+oscillator&tbm=isch
    A common result there is the op-amp-based circuit, which is the op-amp-based "negative resistance" circuit (see http://www.google.com/search?q=negative+resistance+circuit&tbm=isch for other ways of making a negative resistance circuit) connected across the LC tank.
    The op-amp circuit normally uses a split supply, i.e. a positive supply rail, a 0V rail, and a negative supply rail; typically these are ±15V though ±12V and ±9V are OK too. If a split supply isn't available, the circuit can be modified. Suitable op-amps for that circuit would be TLE2071 (http://www.digikey.com/product-detail/en/TLE2071CP/296-10419-5-ND/380933), TLE2081 (http://www.digikey.com/product-detail/en/TLE2081CP/296-10438-5-ND/380941), OPA604 (http://www.digikey.com/product-detail/en/OPA604AP/OPA604AP-ND/251162), OP42 (http://www.digikey.com/product-detail/en/OP42GPZ/OP42GPZ-ND/1007334), or dual versions of those ICs.
    The oscillator can then be fed through a comparator to convert its output into a clean square wave.
    If you need an exact 50% duty cycle, the simplest option is to feed the comparator's output signal into a flip-flop connected as a divide-by-two circuit or "T" ("toggle") flip-flop. For example, half of a CD4013 with the D (data) pin connected to the Q-bar output will do this.
