Orcad express question
Discussion in 'CAD' started by A E, Aug 7, 2003.
  1. A E
    A E Guest
    I'm a Viewlogic guy just using again Orcad after a long hiatus from Orcad (SDT
    was the last OrCad product I used)
    I'm creating a part. I have tons of ground pins. The way I've seen it done is to
    use zero-length invisible power pins, one for each ground pin, and then you
    sprinkle them around the part. Isn't there a way to create a pin with multiple
    pin numbers, without having Orcad complain that you have multiple pins with the
    same name? I can't really use a bus because the pin numbers don't follow.
    Also, I have power pins that need the same treatment. You know, the usual Vdd,
    Vd, PVd thing on big ASICs so I can decouple each rail seperately...
    I'm sure it's something simple, but the help is less than helpful on these
    subjects. The problem is the 'pin with same name' error I'm getting. Will this
    prevent netlist generation?
  2. Boris Mohar
    Boris Mohar Guest
    It is not an error but a warning. Go ahead and use the same name. The
    netlist generator should not care.
    Regards,
    Boris Mohar
    Got Knock? - see:
    Viatrack Printed Circuit Designs http://www3.sympatico.ca/borism/
    Aurora, Ontario
  3. A E
    A E Guest
    Great, thanks!
  4. Boris Mohar
    Boris Mohar Guest
    Fluffo?? Please enlighten me.
    Regards,
    Boris Mohar
    Got Knock? - see:
    Aurora, Ontario
  5. Boris Mohar
    Boris Mohar Guest
    You would not want to do that with your secretary of state now, would
    you?
    Regards,
    Boris Mohar
    Got Knock? - see:
    Aurora, Ontario
