orcad 9.1 express
Discussion in 'CAD' started by morosh, Feb 20, 2006.
  1. morosh
    morosh Guest
    Hello:
    I'm newbie to Orcad 9.1 express, I'd like to synthesize a gal22v10 with
    a simple vhdl file just to test,
    I wrote the following file:
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.STD_LOGIC_UNSIGNED.all;
    use WORK.mylib1.all;
    entity cmp_bdt is
    port(
    CLOCK : in std_logic;
    RESET : in std_logic;
    CK1 : out std_logic;
    CK2 : out std_logic;
    CK3 : out std_logic);
    end cmp_bdt;
    architecture arch_behavioral of cmp_bdt is
    -- Component declarations
    -- Signal declarations
    signal cpt : std_logic_vector(2 downto 0);
    begin
    GEN_CPT: process(CLOCK,RESET)
    begin
    if (CLOCK'event and CLOCK='1') then
    if (RESET='1') then
    CPT <= "000";
    else
    CPT <= CPT + 1;
    end if;
    end if;
    end process;
    CK1 <= cpt(0);
    CK2 <= cpt(1);
    CK3 <= cpt(2);
    end arch_behavioral;
    I tried to build, I get errors and the following report:
    OrCAD Simple PLD Fitter tools
    OrCAD PLD FITTER x1.11 11/5/98 (Source file
    e:\My_data\dev\vhdl\orcad\gal22v10\Timed\gal22v10.jed
    Copyright (C) 1988-1998 OrCAD All Rights Reserved.
    1. Parsing input file
    2. Loading device tables
    3. Converting pin connections
    4. Expanding source statements
    Signal EXP_N532
    Signal EXP_N535
    Signal EXP_N531
    Signal EXP_N534
    Signal EXP_N530
    Signal EXP_N533
    Signal EXP_N528
    Signal EXP_N515
    Signal EXP_N523
    Signal EXP_N529
    Signal EXP_N526
    Signal EXP_N524
    Signal EXP_N527
    Signal EXP_N525
    Signal EXP_N514
    Signal EXP_N518
    Signal EXP_N517
    Signal EXP_N522
    Signal EXP_N520
    Signal EXP_N521
    Signal EXP_N519
    Signal EXP_N513
    Signal EXP_N146
    Signal EXP_N143
    Signal EXP_N140
    Signal EXP_N131
    Signal EXP_N130
    Signal EXP_N129
    Signal CK1
    Signal CK2
    Signal CK3
    Signal EXP_N512
    Signal EXP_N137
    Signal EXP_N135
    Signal EXP_N133
    5. Reducing equations
    Signal CK1
    Signal CK2
    Signal CK3
    Signal EXP_N137
    Signal EXP_N135
    Signal EXP_N133
    6. Configuring architectural fuses
    ERROR (PLD2763) Signal RESET is not input to the array.
    ERROR (PLD2763) Signal CLOCK is not input to the array.
    7. Generating fuse array
    WARNING (PLD1364) Signal CK1 is not output from the array.
    WARNING (PLD1364) Signal CK2 is not output from the array.
    WARNING (PLD1364) Signal CK3 is not output from the array.
    ERROR (PLD2766) Signal EXP_N137 does not have a valid clock portion.
    ERROR (PLD2765) Signal EXP_N137 has too many product terms.
    ERROR (PLD2766) Signal EXP_N135 does not have a valid clock portion.
    ERROR (PLD2765) Signal EXP_N135 has too many product terms.
    ERROR (PLD2766) Signal EXP_N133 does not have a valid clock portion.
    ERROR (PLD2765) Signal EXP_N133 has too many product terms.
    8. Checking for error conditions
    NOTE (PLD0200) Eight fatal errors found in input file.
    NOTE (PLD0201) Three warnings.
    9. Writing language file
    NOTE (PLD0202) 2/19/6 6:52 pm (Sunday)
    NOTE (PLD0204) Elapsed time 6 seconds
    Adding files to PM:
    Adding e:\My_data\dev\vhdl\orcad\gal22v10\Timed\GAL22V10.LST
    Adding e:\My_data\dev\vhdl\orcad\gal22v10\Timed\GAL22V10.VHD
    Can someone help? I like to know also how to assign in/out signals to
    pins?
    Morosh ()
  2. Joseph2k
    Joseph2k Guest
    Well "doh"! Orcad is a reasonably good analog schematic capture tool, but
    it is not a front end to VHDL or Verilog; they have their own front ends.
  3. Actually, no. Orcad Express was a VHDL tool, that used Capture as its
    front end, and not too bad a one at that. It was lost after the
    purchase by Cadence.
    Charlie
  4. Joseph2k
    Joseph2k Guest
    If you find it so fine for you. I had always accepted that VHDL was a move
    to behavioral modeling (ignited by Conway-Meade) per the US military VHSIC
    program; which was a move away transistor level modeling. Of course a good
    generalized schematic capture tool might very well do the job. Don't get
    me wrong, i liked Orcad back in the 1980's when i had a running version.
