+ or - on a capacitor
hyudryu
Feb 24, 2010
64
Feb 24, 2010
64
I bought a 10uF 16V tantalum capacitor surface mount and im not sure which is negative. Its yellow and im assuming that the brown strip has to do with the polarity but im not sure if thats positive or negative:confused: Help please. Thanks:p
Resqueline
Jul 31, 2009
2,848
Jul 31, 2009
2,848
Tantalums have their polarity mark on the positive side, which also "happens" to be on the right side when facing the text and having the pins pointing down.
hyudryu
Feb 24, 2010
64
Feb 24, 2010
64
Thanks. I read somewhere that those surface mount capacitors can blow up if not connected correctly.
hyudryu
Feb 24, 2010
64
Feb 24, 2010
64
And i desoldered a surface mount electrolytic capacitor that is silver and has a black stripe at the end that looks like a half moon. How do i read it?
It says:
100
6s
CD5
What does that mean?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
That's kinda true of any polarised capacitor. Some may not blow up, but it's a bad idea.
like this?
How do i read it?
It says:
100
6s
CD5
Not sure. Possibly 100 uF
(*steve*)
25,510
25,510
Where did it come from? And what size is it? It's not a completely reliable measure, but capacitors get larger as their capacitance and voltage ratings increase. If the size corresponds to a 100uF 5V or 6V electrolytic, and it came from logic circuitry powered by (or having a regulator providing) 5 volts, then its likely that the 5 or 6 corresponds to the voltage.
hyudryu
Feb 24, 2010
64
Feb 24, 2010
64
If there is no brown strip, is it not polarized?
Also, do you know how to read the numbers and letters on a small tantalum Surface mount capacitor? I bought 2 kinds but i can't remember which one was which
(*steve*)
25,510
25,510
There should be some method of identifying the +ve or -ve lead. The specs should tell you.
The specs will also likely tell you what markings you should expect to see on the capacitors.
If you don't have the specs, and can't find out the manufacturer and part number of the caps then take a good sharp photograph of them with the markings readable and we'll have a go for you.
hyudryu
Feb 24, 2010
64
Feb 24, 2010
64
Ok thanks :D
The font is a little wierd i think its"
D2LE
B47
9714
Resqueline
Jul 31, 2009
2,848
Jul 31, 2009
2,848
The brand name is Dale. I'd expect the B to be a code for the voltage rating and 47 is the capacitance, possibly 0.47uF. 9714 is the manufacturing date; 1997, week 14.
(*steve*)
25,510
25,510
And looking at it, it doesn't look like a polarised capacitor.
hyudryu
Feb 24, 2010
64
Feb 24, 2010
64
I get it now I get how to read it:D THANKS A LOT
