Optoisolator question
Discussion in 'Electronic Basics' started by [email protected], Feb 11, 2008.
  1. Guest
    Hi! A simple question. I want to use the TLP280 photocoupler. What is
    the spec that tell me the maximum voltage I can put in the ouput?
    Ideally I want to be able to drive a maximum of 24V.
    Thanks!
  2. Tim Wescott
    Tim Wescott Guest
    This should be in the data sheet. If it's an open-collector type it'll
    be the VCE rating of the output transistor; if it's a PIN diode type
    it'll be the reverse bias spec on the output diode.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Do you need to implement control loops in software?
    "Applied Control Theory for Embedded Systems" gives you just what it says.
    See details at http://www.wescottdesign.com/actfes/actfes.html
  3. Eeyore
    Eeyore Guest
    You need the collector-emitter voltage rating. It's 80V according to
    this.
    http://www.toshiba.com/taec/components2/Datasheet_Sync//206/4193.pdf
    Graham
