Optoisolator Circuit
Discussion in 'General Electronics Discussion' started by WaltP, Jun 16, 2017.
  1. WaltP
    WaltP
    10
    Jun 16, 2017
    Hi. I'm a bit of a newbie slowly working my way up the learning curve. Could someone please help with a circuit and choice of transistor to increase the current output from a proximity sensor (LCZ260) in order to trigger an opto isolator - I'm using a 6N137. The proximity sensor output at 5 volts is .5 to 1.1 ma depending on resistor choice which I need to boost to around 10 ma in order to trigger the 6N137. Thanks in advance.
    Walt
  2. AnalogKid
    AnalogKid
    2,571
    739
    Jun 10, 2015
    Can't draw a sch right now.
    2N7000 or 7002 MOSFET:
    Sensor output to gate
    Source to GND
    Drain to 6N137 cathode
    6N137 anode to 220 ohm resistor.
    220 ohm resistor to +5 V.
    2N4401, 3904, 2222 Bipolar transistor:
    Sensor output to 1K resistor
    1K resistor to NPN transistor base
    Transistor emitter to GND
    Collector to 6N137 cathode
    ak
  3. WaltP
    WaltP
    10
    Jun 16, 2017
    Many thanks, I'll give it a run.
    Edit: Happen to have a 2N7000 and it worked quite nicely. Changed to a 560 ohm resistor which put me at 10 ma. Again, thanks for for help. If you feel like responding again, is there any advantage or disadvantage to a mosfet. If I interpreted the datasheet correctly, response time seems faster at lower voltages which, I think, would be in the 20 nanosecond range. Are bipolar transistors faster?
    Walt
  4. Minder
    Minder
    3,181
    690
    Apr 24, 2015
    One advantage of a mosfet is it offers high input impedance over bi-polar.
    M.
  5. (*steve*)
    25,501
    2,841
    One disadvantage of the MOSFET is it's high input impedance.
    Ok, that's a bit tongue in cheek, but the differences between components can be advantageous or detrimental. They are almost always a double edged sword.
  6. Minder
    Minder
    3,181
    690
    Apr 24, 2015
    I vary rarely use bi-polar transistors any more if I can help it.
    M.
  7. BobK
    7,682
    1,688
    Bipolar transistors behave better when doped with Lithium.
