Optocouplers
Discussion in 'Electronic Design' started by Steve, Sep 8, 2006.
  1. Steve
    Steve Guest
    Optocouplers.
    I'm looking for an alternative to the Isocom CSM170. I only want a
    handful and they are talking in MOQ terms of 1000 pcs :-(
    It appears to be the holy grail of opto/layout solutions for a micro
    controller port. I'm surprised there isn't anything out there... or is
    there ?
    MTIA,
    - Steve
  2. Eeyore
    Eeyore Guest
    What's that ?
    Graham
  3. James Beck
    James Beck Guest
    I went to www.isocom.com and did a search for CSM170 and had no hits at
    all. Tried just the "CSM" and the "170" also no joy. Gonna need more
    info than a part number that does not work.
    Jim
  4. Steve
    Steve Guest
    The clue was in the title, but take a look here:-
    http://www.yi23.dial.pipex.com/csm170.htm
    - Steve
  5. Joerg
    Joerg Guest
    Hello Steve,
    While a multi-opto is nice it is IMHO not the holy grail if Digikey
    doesn't carry it and you can't get low qties anywhere. Maybe you could
    look at 4-ch versions that are more available. NEC, Toshiba etc.
  6. Joerg
    Joerg Guest
  7. Steve
    Steve Guest
    4ch is clearly a step in the right direction, but if you want to
    optoisolate a whole port at once then the CSM170 would be a lovely chip
    to use. I'm currently using a 6N137, which means one chip per pin.
    Obviously a pin to pin layout would make life oh so much easier for
    layout purposes.
    Afterall, I have an 8ch driver in the ULN2803A on the output port, so
    something to match on the other side of the MCU would be perfect.
    - Steve
  8. Steve
    Steve Guest
    try http://www.yi23.dial.pipex.com/csm170.htm
    - Steve
  9. Joerg
    Joerg Guest
    Hello Steve,
    The 137 is a good device. I used the CNW137 wide body version a lot.
    Sure. But I try to stay away from boutique parts. They may offer a
    really elegant solution and then bite you from behind. For example when
    the purchasing manager shows up in your office all red in the face
    because his buyers can't get any.
    Depending on what is transmitted there may be other options. I like LAN
    transformers for isolated transfers. Of course, then you need Schmitts
    on the other side and you may have to nudge them into a start position
    after system turn-on if needed.
  10. Eeyore
    Eeyore Guest
    I gather that much but someone else had already tried to find it and failed.
    Ok. So what's the problem ?
    Graham
  11. Steve
    Steve Guest
    It's a 8 opto package.
    - Steve
  12. Steve
    Steve Guest
    Absolutely..!
    I was chatting with one of our engineers, and he agreed that seems an
    obvious part when you think about it. I'm surprised that the bigger
    companies have never made such a thing.
    The main reason I need opto's, is because I'm using 24V throughout the
    rest of the kit (hence the 2803) with photocells and limit switches on
    inputs and pneumatic valves on the outputs, all in a very noisy
    environment, a factory !
    Ho hum... looks like the two quads I have sitting in front of me are
    going to get designed in instead.
    - Steve
  13. Eeyore
    Eeyore Guest
    And ?
    Graham
  14. John Fields
    John Fields Guest
  15. Steve
    Steve Guest
    And ?
    Graham
    [/QUOTE]
    It's 18 pin.
    - Steve
  16. Eeyore
    Eeyore Guest
    Really ?
    I'm actually asking him to get to the point ! Something that didn't happen 'til
    recently.
    Graham
  17. Eeyore
    Eeyore Guest
    It's 18 pin.[/QUOTE]
    And you want 8 couplers in one package ?
    If it's a DIL package you're currently using, why not use a couple of SMD quads
    instead ?
    Graham
  18. John Fields
    John Fields Guest
  19. John Fields
    John Fields Guest
  20. Steve
    Steve Guest
    I figured that, I'm just playing with him now...
    - Steve
