Optocoupler
Discussion in 'Electronic Components' started by Fred Bartoli, Jan 22, 2013.
  1. Fred Bartoli
    Fred Bartoli Guest
    anyone knows who made the KT3172 optocoupler, and may be has a datasheet?
    It seems I can't find it.
  2. Jamie
    Jamie Guest
    Like a lot of numbers..
    from what I can see it is a 4 pin device ? and if so, the pins 1 and 2
    are the input LED or LED's, if could be an AC type? to test that, you
    can use the diode test and it should test the same both ways as a LED
    diode.
    The output looks like a NPN transistor. Collector is on 4 and emitter
    on 3.
    But, maybe I have it incorrect..
    JAmie
  3. Franc Zabkar
    Franc Zabkar Guest
  4. Franc Zabkar
    Franc Zabkar Guest
