Optocoupler meeting EN60079-11 standard
ranjithrnair
Jun 14, 2018
Jun 14, 2018
Hi
would like to know the optocouplers that meet the EN60079-11 standard for safety.
minimum external clearance- 8mm
minimum internal clearance-0.5mm
ranjithrnair
Jun 14, 2018
Jun 14, 2018
already googled.....found many....but power dissipation is too high.... dissipation between 10 to 30mW is required...pls tell if u find any in this range....external clearance can be reduced upto 4mm
Harald Kapp
13,700
13,700
Which power do you refer to? On the input side (LED), output side (if an IC-coupler is used)?
Which data rate do you need.
You should have stated this additional requirement in your first post. We can't guess your requirements.
Please state all your requirements.
4.th hit in my search: This coupler has an input power dissipation of 20.5 mW worst case. Where did you look?
That's quite a difference to the 8 mm from your post #1. How come? Are you sure that's covered by EN60079-11 in your application?
