Opto coupler
Discussion in 'Electronic Basics' started by lerameur, Jan 25, 2007.
  1. lerameur
    lerameur Guest
    hello,
    I have bought the MCT6 chip (opto coupler)
    I grounded pin 3 and 5
    If I put a voltage a cross pin 4 should I get the same voltage across
    pin 6 ??
    I am not getting anything
    k
  2. lerameur
    lerameur Guest
    I also put pin 6 to Vcc and a resistor to pin 5 to ground, and take
    the voltage at pin 5 , but no luck either
    k
  3. John Fields
    John Fields Guest
    That's because you're hooking it up wrong.
    You should be doing it like this: (View in Courier)
    +5V>-+-------------+
    S1 | |
    O |
    [360R] [2K5]
    | +------>VOUT
    |3 |5
    | | C |
    |[LED]--> B |
    | | E |
    | | OPTO | |
    |4 |6
    GND>------+--------+------>GND
    Or like this:
    S1 | |
    O |
    [360R] |
    |3 |5
    | | C |
    |[LED]--> B |
    | | E |
    | | OPTO | |
    |4 |6
    | +------>VOUT
    | [10k]
    GND>------|--------+------>GND
    In the first example, when S1 is open VOUT will be close to 5V and
    when S1 is closed VOUT will be close to 0V (0.5V or something like
    that).
    In the second example, when S1 is open VOUT will be very close to 0V
    and when it's closed VOUT will be close to 5V.
  4. lerameur
    lerameur Guest
    Thanks JF
    This is a similar circuit found on one spec sheet.
    I took a snapshop of the circuit and posted here:
    http://www3.sympatico.ca/lerameur/
    infortunately it still not working
    ken
  5. Chris
    Chris Guest
    OK, lerameur. First off, you might want to look at the datasheet:
    http://www.nteinc.com/specs/3000to3099/pdf/nte3086.pdf
    Also, your picture shows that the MCT6 collector is connected to GND
    through the 10K resistor, and your emitter is connected to +5V. Switch
    those two and it should work, unless you let out the magic smoke
    already.
    It's always a good idea to look at the datasheet before you plug it in.
    Cheers
    Chris
  6. lerameur
    lerameur Guest
    I also switch the cathode and anode from the diagram shown.
  7. ehsjr
    ehsjr Guest
    Right. You need to have pin 3 and pin 5 connected to ground.
    You need pin 6 connected to the 10K resistor - the other end
    of the resistor goes to (+). (Might be a 1K resistor - I
    can't tell if that is a red or an orange band)
    The other resistor connects from pin 4 to +5 volts, but
    I'd change it to 220 ohms.
    Ed
  8. lerameur
    lerameur Guest
    Ok great its working, thank you
